Sway bar turned over after hitting bump.
It is probably too late for this, but I also had the same problem when I had my shocks changed, I just pushed the sway bar back while the truck was lifted and it fixed it. Unfortunately the end links are now bent. I went over a bump real fast and the sway bar flipped down again. I am going to replace the damn end links and hopefully this won't happen again. I thought I was the only one who had this problem. I guess in some way I am kind of happy to see I'm not the only one. It's an easy fix anyway, I'm glad you got it fixed.
