Re: electric brake?
No matter what Titan you have with or without the Big Tow package you MUST purchase a separate brake controller. If you don't already have the Big Tow package then you will need the relays.
The wiring harness for the brake controller is located up in the dash above the emergency brake.
I bought the Prodigy brake controller and the Titan wiring adapter so I wouldn't have to do any wiring and also so it could be quickly removed.
Jim
