po man's posi
another approach is to use one airbag on the pass side rear pumped to about 15 pounds. that will compensate for the engine torque driver's side lift and while not a full posi, it will give you better traction with both wheels especially on take off. looks like there is a good place for it by taking off the bump stop and putting in the air bag in that position.
the ultimate the "lincoln locker." weld the spider gears down with a lincoln arc welder - acutally only good for circle track:>).
juma
