Old 08-27-2008, 03:57 PM   #8 (permalink)
HRTKD
HRTKD's Avatar
Re: Had an accident today (got pics), need opinions on fixing
If the tire came into contact with the wheel well that hard I would check for frame, suspension, wheel and tire damage. How is it that the topper came off? If mine came off then it would be toast as the anchors are built into the bottom rail. If the topper is cracked then it would likely have to be replaced, not repaired. Then again I'm no fiberglass expert, it's my understanding that you don't repair fiberglass when it cracks.
Jim
