Old 09-05-2008, 10:21 AM   #24 (permalink)
rtc1184
rtc1184's Avatar
Send a message via AIM to rtc1184 Send a message via Yahoo to rtc1184
Re: List your Titans Mechanical Failures
just a thought, why dont you put the year of yall's truck when posting problems so we can see what yr most of the things are happening so we can check our trucks if they are the same year
2007 KC 2wd White
modswanted: UPREV ECU FLASH
BIG BRAKE UPGRADE
STEEL BRAIDED BRAKE LINES
MASTER CYLINDER STIFFNER
REMOTE START
REPLACEMENT BUMPERS
BULLETPROOF FRONT CLIP
SHACKLE FLIP THE REAR
MODS DONE!
REMOVED ALL THE DECALS,TINT, CAI, STRAIGHT PIPE EXHAUST, BALLISTIC OFFROAD JESTER'S 17X 9 -12MM OFFSET, 6" BASIC FABTECH LIFT, STACKED LEVELING KIT, 37x13x17 SUPER SWAMPER BOGGERS, 3"BODY LIFT, HITCH, 1 - 15" KICKER SOLO BARIC L7, CRUNCH 1500.1 AMP, THROTTLE BODY SPACER, PAINTED INDIGO BLUE INTAKE COVER,BURNOUT MOD,LED 3RD BRAKE LIGHT, BLUE LED'S UNDER DASH, WHITE FACE GAUGES, TB COOLANT BYPASS, AXLE VENT MOD, 2* TIMING ADVANCE, SUPERCHIPS PROGRAMMER, BLUE L.E.D. DOME LIGHT, CUSTOM MADE ROCK SLIDERS, DDM 35W 8000K LOW BEAM, DDM 35W 8K HIGH BEAM, MILE MARKER 12,000LB WINCH, 8-6" 100WATT OFFROAD LIGHTS, MY MADE LIGHT BAR, MY MADE FRONT BUMPER WITH WINCH MOUNT, LINE X BEDLINER, LINE X ROCK SLIDERS, LINE X ROCKER PANELS AND BOTTOM OF THE BED,
10.5" INGSIGNIA MOTORIZED FLIP DOWN SCREEN, SONY XPLOD W/ BUILT IN BLUE TOOTH AND AUX PORT, BACK UP CAMERA
www.myspace.com/stuntin4alivin
rtc1184 is offline   Reply With Quote
