Ressurecting an old thread...
I don't have a lot of experience with car wiring (understatement of the year), but the brake controller looks straighforward enough. I haven't looked closely at the wiring pigtail that comes with the truck and don't have the controller yet (ordering it today). I'm assuming the pigtail has a connection at one end and just wires at the other, as does the controller wiring. Given that, what did you use to connect the wire ends? Wire nuts? Soldered?
Thanks in advance.
EDIT: Also, is the 7-pin connection at the hitch standard as far as what connection controls which function? Is there a standard? Should the RV place (who'll install the hitch and connector from the truck to the RV) know?
Titan SE CC 2WD
Smoke / Graphite
Pop. Pkg. w/Capt., Big Tow, Util. Bed Pckg.,
Splash, Mats, Fog Light Kit, Step Rails
Leer 100R Cap
Hornet Lite 24RS Travel Trailer
Reese Straight-Line Hitch (WD System with
Dual Cam Sway Control) Prodigy Brake Controller
