Old 05-28-2004, 12:58 AM   #11 (permalink)
TrojanDan
Originally Posted by pciley
Then when you put your load in the bed it will ride lower in the rear than the front and will look worse IMO. It's so hard to find a happy medium between riding stinkbug (factory 2-3" higher in rear) and riding like you have airbags dumped in the rear when you are carrying 400 lbs or more.
I'm sure if you go with the 8"CST lift which handles frickin AWESOME for an 8" lift, then when you add the wider wheels/tires combo, your CG being higher will almost cancel with the wheelbase being wider and probably will have about the same stability. I wouldn't go whipping around turns too fast in any pickup truck, they aren't made for it and most don't have independent rear suspension. OOOOOH, another idea the for the '05 Titan.. independent rear suspension. (wont happen)
I agree dude, it looks horrible when you drop the *** end. I also agree, it handles friggin great for such a tall lift, and it has (partially) to do with the wider tires and wheel base. But I don't agree about the IRS dude, that would be horrible. So weak back there for carrying a load, haulin and offroadin. Lift kits would be a lot more expensive than they already are as well! I hope they keep the rear leaf springs always - kinda isn't a truck anymore if you lose those.
TrojanDan is offline   Reply With Quote
