Old 10-01-2008, 11:51 PM   #40 (permalink)
Hawaiianbasshead
Hawaiianbasshead's Avatar
Re: What MPG are you guys getting with your Fat A55 35 inch tires
I have 35z on 20"s I get a steady 10mpg tank to tank...
also with 10" wide wheels backspace doesn't matter... you'll always rub.. because you can only fit 5.5ish backspace... I have 5.79 and my toyo MTs rub the frame was thinking of getting 13.5"s for the next set but not sure now maybe I'll put on my 1/4" wheel spacers one day... or just stick some 2" ones on and see how much I rub the place where my pinch weld used to be
05 xe 4x4
Go: aFe stg2, TBS, TB coolant bypass, flowmaster Y pipe w/borla pro XS muffler, BD PP, DT LT headers
Ext: 2.5" leveling kit, Fabtech add-a-leaf, PRG UCAs, SAW Piggybacks in rear 3" body lift, 35x12.5 toyo MTs on 20x9" +18mm offset ultrawheels titan 6 black, ventshades, headlight covers, 5% tint all around and n-fab steps, PRG traction bars
Int: wet okole seat covers front and back, custom 7" screen cut into last fold down pocket of over head console. active 3 way front stage 8" Peerless SLS woofers in doors, 4" xtant XSC/morel mids at a-pillars in glass pods (gloss black painted) and (Blau VC100 rainbow cal25 based) tweets run off an audio art 260.6xe, preamped via arc audio eq
substage always chaging, single Storm neo/neo 3hp motor'd 10" with FI soft parts in 2.5cubes ported after displacements 6" PSP port tuned to about 38hz.
