Old 10-16-2008, 07:57 AM   #3 (permalink)
firefightintitan
firefightintitan's Avatar
Re: i-tunes/iphone help pls
Right click the song that you purchased that you wish to turn into a ringtone, in the sub-menu when you right click there will be an option to "use as ringtone" click that, if it's available it will let you select the part of the song you wish to make a ringtone and then you purchase it for .10. Then after you re-sync your phone insuring that the ringtones are selected to be synced, go to the settings of your iphone, go to sounds, then ringtones, then there should be a list of the ringtones you've made and can select.
firefightintitan is offline   Reply With Quote
