Re: i-tunes/iphone help pls
Originally Posted by bills1974
There is an easier way to do it for free...Have fun
Go into your iTunes preferences, and make sure you are using the AAC encoder. You can double-check this by going to “Advanced”, then “Importing”. Now, browse to the song you want to use to create your ringtone. Right click on the file, and choose “Get Info”, then “Options”. Under the Options tab, select te start time and stop time, to create a 30 second clip. Once your 30 second clip is selected, right-click the song and choose “Convert Selection to AAC”.
Once the conversion is completed, you will get a 30 second song of the same name. At this point, you can edit the original file back to its normal length. Now, browse to your iTunes music folder. You should find the new clip in the same folder the full-length song is in. Notice that the clip has an extension of .m4a. Simply rename the extension to .m4r, then select it. It will automatically be added as a ringtone in your iTunes library.
it says i cant conervt it cause it is protected. i have bought 20 songs today and every damn one of them say that same thing.!!! i am hating this phone already.
2007 KC 2wd White
modswanted: UPREV ECU FLASH
BIG BRAKE UPGRADE
STEEL BRAIDED BRAKE LINES
MASTER CYLINDER STIFFNER
REMOTE START
REPLACEMENT BUMPERS
BULLETPROOF FRONT CLIP
SHACKLE FLIP THE REAR
MODS DONE!
REMOVED ALL THE DECALS,TINT, CAI, STRAIGHT PIPE EXHAUST, BALLISTIC OFFROAD JESTER'S 17X 9 -12MM OFFSET, 6" BASIC FABTECH LIFT, STACKED LEVELING KIT, 37x13x17 SUPER SWAMPER BOGGERS, 3"BODY LIFT, HITCH, 1 - 15" KICKER SOLO BARIC L7, CRUNCH 1500.1 AMP, THROTTLE BODY SPACER, PAINTED INDIGO BLUE INTAKE COVER,BURNOUT MOD,LED 3RD BRAKE LIGHT, BLUE LED'S UNDER DASH, WHITE FACE GAUGES, TB COOLANT BYPASS, AXLE VENT MOD, 2* TIMING ADVANCE, SUPERCHIPS PROGRAMMER, BLUE L.E.D. DOME LIGHT, CUSTOM MADE ROCK SLIDERS, DDM 35W 8000K LOW BEAM, DDM 35W 8K HIGH BEAM, MILE MARKER 12,000LB WINCH, 8-6" 100WATT OFFROAD LIGHTS, MY MADE LIGHT BAR, MY MADE FRONT BUMPER WITH WINCH MOUNT, LINE X BEDLINER, LINE X ROCK SLIDERS, LINE X ROCKER PANELS AND BOTTOM OF THE BED,
10.5" INGSIGNIA MOTORIZED FLIP DOWN SCREEN, SONY XPLOD W/ BUILT IN BLUE TOOTH AND AUX PORT, BACK UP CAMERA
www.myspace.com/stuntin4alivin
