Old 10-20-2008, 08:28 PM   #5 (permalink)
Hawaiianbasshead
Hawaiianbasshead's Avatar
Re: CAN I REALLY FIR 35's WITH A 6 INCH LIFT ??
I have 20x9" +18 offset 2.5" leveling kit and 3" body lift which is about 5.5" lift. and had to do the pinch weld mod to clear the used 35"s I'm running and still rub on full lock on one side. I may just need to redo the pinch weld cutting. but your best bet is getting wheels that don't stick out much. pulling the mud flaps and possibly doing the pinch weld mod... search pinch weld mod or pwm and you'll find the how too's and pix and what not no I don't have mudflaps on anymore. pulled them to clear my 33"s with 17x9" 4.5" BS
05 xe 4x4
Go: aFe stg2, TBS, TB coolant bypass, flowmaster Y pipe w/borla pro XS muffler, BD PP, DT LT headers
Ext: 2.5" leveling kit, Fabtech add-a-leaf, PRG UCAs, SAW Piggybacks in rear 3" body lift, 35x12.5 toyo MTs on 20x9" +18mm offset ultrawheels titan 6 black, ventshades, headlight covers, 5% tint all around and n-fab steps, PRG traction bars
Int: wet okole seat covers front and back, custom 7" screen cut into last fold down pocket of over head console. active 3 way front stage 8" Peerless SLS woofers in doors, 4" xtant XSC/morel mids at a-pillars in glass pods (gloss black painted) and (Blau VC100 rainbow cal25 based) tweets run off an audio art 260.6xe, preamped via arc audio eq
substage always chaging, single Storm neo/neo 3hp motor'd 10" with FI soft parts in 2.5cubes ported after displacements 6" PSP port tuned to about 38hz.
