Re: CAN I REALLY FIR 35's WITH A 6 INCH LIFT ??
Mudflaps gone, partys on...
For 35"s you'll need the PWM also...Or you can go extreme PWM...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
