Old 10-21-2008, 01:17 PM   #8 (permalink)
rtc1184
rtc1184's Avatar
Send a message via AIM to rtc1184 Send a message via Yahoo to rtc1184
Re: CAN I REALLY FIR 35's WITH A 6 INCH LIFT ??
Originally Posted by yamatitan View Post
You dont need a pinch weld mod for 35's with a 6" lift
yamatitan is correct tom, you dont need the pwm to fit 35's on a 6" lift. you will though probably have to take your mud flaps off. get a rim that is 4.5mm backspacing with little to no -offset. you should be fine. im running 38.5's on a 17x8 4.5bs no offset. i have 11"s of lift, but these rims had 35s on them on a 6" lift previously
2007 KC 2wd White
modswanted: UPREV ECU FLASH
BIG BRAKE UPGRADE
STEEL BRAIDED BRAKE LINES
MASTER CYLINDER STIFFNER
REMOTE START
REPLACEMENT BUMPERS
BULLETPROOF FRONT CLIP
SHACKLE FLIP THE REAR
MODS DONE!
REMOVED ALL THE DECALS,TINT, CAI, STRAIGHT PIPE EXHAUST, BALLISTIC OFFROAD JESTER'S 17X 9 -12MM OFFSET, 6" BASIC FABTECH LIFT, STACKED LEVELING KIT, 37x13x17 SUPER SWAMPER BOGGERS, 3"BODY LIFT, HITCH, 1 - 15" KICKER SOLO BARIC L7, CRUNCH 1500.1 AMP, THROTTLE BODY SPACER, PAINTED INDIGO BLUE INTAKE COVER,BURNOUT MOD,LED 3RD BRAKE LIGHT, BLUE LED'S UNDER DASH, WHITE FACE GAUGES, TB COOLANT BYPASS, AXLE VENT MOD, 2* TIMING ADVANCE, SUPERCHIPS PROGRAMMER, BLUE L.E.D. DOME LIGHT, CUSTOM MADE ROCK SLIDERS, DDM 35W 8000K LOW BEAM, DDM 35W 8K HIGH BEAM, MILE MARKER 12,000LB WINCH, 8-6" 100WATT OFFROAD LIGHTS, MY MADE LIGHT BAR, MY MADE FRONT BUMPER WITH WINCH MOUNT, LINE X BEDLINER, LINE X ROCK SLIDERS, LINE X ROCKER PANELS AND BOTTOM OF THE BED,
10.5" INGSIGNIA MOTORIZED FLIP DOWN SCREEN, SONY XPLOD W/ BUILT IN BLUE TOOTH AND AUX PORT, BACK UP CAMERA
www.myspace.com/stuntin4alivin
rtc1184 is offline   Reply With Quote
The Following User Says Thank You to rtc1184 For This Useful Post:
TITANTHOMAS (10-22-2008)
