Old 06-04-2004, 08:40 PM   #1 (permalink)
Sammy Sandbag
Sammy Sandbag's Avatar
Custom Sub Box Project
::EDIT::
To see my second custom box, go here:Custom Sub Box Project :: Part II
::END EDIT::
I just finished up a little project, well finished one phase anyways. I had an old sub box with two Rockford 8"s in it just sitting in the garage. The box was too big to fit anywhere in my CC, so I decided to fab one myself. The plan was to make it fit under the rear seat on the driver's side. The dimensions are pretty tight, but I was able to make it work. I think it turned out pretty good for my first time doing this. I still have to wire the amp up. I plan on placing it under the driver's seat after I remove the factory sub. My amp has hi power inputs, which I'll probably wire off of either the rear channel or factory sub powered wires. I'll update once I'm finished.
::EDIT::
Here's the dimensions of the box:
::END EDIT::
-Counsel Yourself
