Old 06-06-2004, 08:17 AM   #3 (permalink)
tnbowhunter
tnbowhunter's Avatar
Originally Posted by Titan Ken
I hitched up my travel trailer just to see how it would look, and was very pleased. The tongue weight is somewhere around 700 lbs. The trailer when loaded weighs about 5000 lbs. When the trailer is hooked up with the weight distribution bars connected, the trailer is level and the truck still sits a little high in the rear end. So if I put some gear in the truck bed, the truck should not squat low in the rear. I found that I only needed to use the third chain link on the weight bars, rather than the fourth as I did with the Tundra. I have the Big Tow package. I haven't towed the trailer yet, but I'm sure it will do just fine.
about the same weight here also, I also found that I went from the third link to the second link on the distribution bars. Tacoma also.
I had a couple of hundred pounds of firewood in the back of mine so it made the rear come down about level.
Radiant silver K/C SE
big tow, off road pkg
Utility bed pkg, bed extender,bed divider
Factory step rails and bug deflector
