just changed mine today after 4,000 miles. fluid level was ok (a little low but acceptable) but man did it look bad. it was dark gray and the drain plug had gunk all over it (not metal but looked like the grease you use to lube up suspension fittings). it looked like my diff had been getting hot too, paint starting to crack and peel, hope i got it in time and the new oil will help, have to keep a close eye.
