Geez touchy are we? He was just kidding. Can't stand the heat get your butt out the kitchen and what not. Either way, I'd like to know how they "redesigned" it? There isn't much you can do with something as simple as a coil spacer, especially if you intend to keep the same dimensions. Even if they changed the rubber compound, it wouldn't fix the shock topping out problem.
-Counsel Yourself
