Old 11-08-2008, 07:15 PM   #1 (permalink)
splifrover
Installing Yakima Rack UPDATED PICS!!!!
Finally finished installing Yakima Racks. The install was pretty straight forward, but I did run into some problems:
1) Had to drill through two layer of metal. The first was sheet and the second was a thicker structural tube that went around the door.
2) When drilling pilot holes into the structural tube we broke two drill bits and had to nock them into the structural tube. (USED BIGGER DRILL BIT)
3) Broke Yakima's PlusNut install tool. Called Yakima and they overnighted the tool for free.
Other than that, the racks look great and the track looks factory. The only down fall is that where I mounted the track, you can not tell if there are any leaks.
Let me know what you all think!
Thanks
splifrover is offline   Reply With Quote
