Originally Posted by SUBTITAN
Remember that heat is the biggest reason for transmission failures, so if your find yourself debating between gas milage or high temps always fail on the temp side and tow in a gear that keeps your temps in the normal range.
Absolutely 100% correct. I burned up a 700R4 in no time flat. The new transmission came with a B&M temperature gauge, and I check it constantly.
The trans cooler side of the radiator on my old truck wasn't providing adequate cooling.
*Every* truck with an automatic transmission should have a temperature gauge. It's a $10 part that can save you thousands.
-Steve
