Old 06-14-2004, 10:24 AM   #7 (permalink)
st38ff2
Bestatchess - THANKS! I went out at lunch and tried the reset and it worked! Do you want me to write the check out to you instead of Nissan?
Rrumaner - The strobes are pretty cool, I put mine in right below the main headlight bulb and with all of the mirrors, they flash really good. If you do put them in, I would drill from the bottom of the light so that the particles come out the hole. The reflector assembly is fiberglass and the dust fills the light and it took a lot of air to get the dust out. I fabircated a plastic disk that I can put on the outer hole and silicone in place to make the light watertight again. I will take a pic and post of the lights and my switch console. I put a row of switches on a fabricated plate in the front overhead drop down pocket. My radio has a remote head, so it is going in the console down in the pen tray.
st38ff2 is offline   Reply With Quote
