Old 11-17-2008, 05:27 PM   #63 (permalink)
Discount Tire
Supporting Vendor
Discount Tire's Avatar
Re: Project: Ballistic Titan
I will have to apologize in advance, the pictures for this install will be mostly close ups because I can't giveaway the finished look of the truck until I have completed all the write-ups. (2 more after this) You'll have to use your imagination for the time being.
Project # 5: Bushwacker Pocket Fenders
Product: Bushwacker Pocket Fenders 70907-02 (Utility Box option)
Installation Time: 1 1/2 Hour
Difficulty: 3 (1-10 scale)
People Needed for the Job: 1 (2 would have been helpful and faster)
Tools Needed: Utility Knife, #2 ratcheting screw driver, Drill w/ 5/16th bit, T45 torx bit (included), 1/2" socket.
Instructions are available for download at Titan Bushwacker Fenders Click "Download instructions sheet". (there are also some pretty good pictures to give you an idea of how the finished product will look.)
First Check for Parts: Driver Front flare(1pc), Pass. Front flare(1pc), Driver Rear Flare(2pc), Pass. Rear Flare (1pc), Hardware bag (1), Edge Trimming (1pc).... Check.
Step one: Install Rubber Trim on the top edge of all flares. Strip backing off in 1ft increments press into place, cut (utility knife) to length after installed.
Step Two: Use Your 5/16" drill bit to drill through dimples in each flare.
Step Three: Insert bolts (don't forget the washers) tighten with 1/2" socket and T45 Torx (Torx included), Repeat a gazillion times.
Step Four: One corner at a time, remove the factory fender lining screws (black ones only) align the Pocket fender up to the truck and reinstall the factory screws. (do not tighten) Install new clips where indicated by instructions. Once all clips and strews are started, double check fender alignment and then tighten each screw.
(new clip proper installation)
Step Five: Install Driver Utility box fender. First strip off edge protector on utility box door.
Align and install 2 piece Driver fender making sure the door has clearance to open and close before tightening fender liner screws.
Step 5: Finished.
Here are a few tease shots, I will post a before and after once all of the write ups are complete.
Installation and Product Review
Once again I am impressed with another after market product. These were easier than I expected to install and would be even easier to take off in the future if you were to choose to. There were a lot of little steps that take some time i.e. drilling all the holes and installing all the bolts, one at a time but it is worth it for the finished look. It was also a little difficult to hold the fender in place while starting the first few screws but once you get two of them in it was easy. All the parts were included. I was happy to see the torx head or it would have cost a trip to the hardware store. And everything aligned nicely. In comparison to some of the horror stories I had heard about tuner body kits not fitting and needing bondo or a skilled fiber glass repair man, these were a piece of cake. I choose to leave them in the matte black finish to match the wheels and I can't wait to show you guys the finished product. They compliment the black accents on the truck nicely. These flares added 2" to the body width and are now protecting the truck from most of the mud and road debris that's getting kicked up by the Mud Grapplers.
Two thumbs up here from me. -Travis
We guarantee the Lowest Delivered Price for tires and/or wheels on the web. We'll do our best to match or beat the competition. We offer free mounting and balancing on packages, and a 30-day satisfaction guarantee! We also offer the industry’s best warranty, and no, it's not pro-rated. Purchase our certificates and if anything goes wrong for the life of your tire, we'll replace it for FREE.
1.888.459.4080
www.discounttiredirect.com
www.myspace.com/discounttiredirect
Discount Tire is offline   Reply With Quote
