Old 11-22-2008, 09:31 PM   #35 (permalink)
Jedbar
Re: Front Axle Failer Thread
"2004-2007 Nissan Titan - Rugged Ridge Locking Hub
Part Number: 15001.45Description:"RUGGED RIDGE LOCKING HUB SET, FOR 31 SPLINE AXLE -- High Quality Locking Hub Set For 31 Spline Axle, Constructed Of Military Spec Hardened Nylon Center Dial That Will Not Damage Other Parts In An Unlikely Event Of Failure, Salt-Spray Tested Epoxy Enamel Finish, Die Cast Aluminum Cap With A Corrosion Resistant Glossy Finish, Internal Components Are Precision Machined And Heat Treated, Provides Better Fuel Economy Due To The Lesser Drag On The Engine, More Mileage For The Front Tires Since They Will Rotate Freely And A More Comfortable Ride Due To The Lighter Steering, Reduction Of Drive Train Noise And Minimal Vibration, Also Provides Better 4Wd Performance When The Hubs Are Locked" Our Price: $152.07"
This is the ad that I found, is it bogus? I can't get the link to work but you can check it out yourself at Auto Parts Warehouse | Car Parts, Truck Parts & Auto Body Parts Online - Free Shipping on most Auto Accessories & Performance Parts - AutoPartsWarehouse and search for your Titan.
Jedbar is offline   Reply With Quote
