Old 06-26-2004, 11:41 PM   #1 (permalink)
BigRedTitan
BigRedTitan's Avatar
Lightbulb Parking Lights WITH FOG LAMPS!!
After STARING at the service manual wiring diagram for the fog lamps, I have figured out that since the lights actuate through the BCM and ECU, there is no way to use the factory set up (replacement turn signal stalk, relay, etc.).
Here is what I did...
Keep in mind that I left the original turn signal stalk installed.
I bought factory fog lamps and an aftermarket relay. I fed two wires through the fire wall. One wire I spliced into the parking light wire (on the harness side, no need to remove light, but you do need to remove the grill). This wire is Red w/ blue stripe. The other end of this wire goes to a switch in the truck. The other wire feeds the switch leg of the relay. I ran a fused wire to the battery. I then ran the power wire off of the relay and attatched it to the fog light connector. To do this, remove some of the electrical tape from the wire wrap. Cut the White w/red stripe wire. Attatch the wire from the relay to the wire going to the connector. You can either run a wire from one light to the other (series) or run a wire from each Light leg of the relay to each light.
I am now going to try to get a fog light rocker switch like the one that I had in my '95 Kingcab. It should fit nicely in one of the blank spaces by the pedal controls. It has the fog lamp symbol on it and has an amber led that lights when they are on.
Bryan
In memory of Chris- CaliforniaTitan
2004 Nissan Titan SE Kingcab
280 rwhp/ 333 max torque
Born on 03/31/2004--Came Home on 04/15/2004
Red Brawn--Graphite/Titanium
Big Tow, Utili-Trac Package, Rockford Fosgate w/ Power Captains Chairs, Rockford Fosgate Punch P550.2 Amp, 2-Rockford Fosgate Punch P110S4 10" Subs,
AutoExtreme Throttle Body Spacer, Flo-Pro Dual Exhaust, Polished Aluminum Billet Grille, ChromeTailgate Accent, 18"X8.5" MB Offroad Gunner 6's,
265/70/18 Bridgestone Dueler A/T REVO's, Garmin nuvi 255W GPS, PRG Mini-Lift W/ 2½" Front Lift/ 1" Rear Blocks, LED's Front, Eagle Eyes LED Tails,
2 Degree Timing Advance , Clifford Matrix 50.5X Security/ Remote Start
BigRedTitan is offline   Reply With Quote
