Old 01-06-2009, 02:03 PM   #4 (permalink)
Kronos1965
Kronos1965's Avatar
Re: 08 Titan drives like paint shaker
Originally Posted by pj202 View Post
I have an 08 SE 4X4 lwb with less than 1000 miles on it that is the most annoying truck I have driven. This thing feels like it is having a seizure when you hit any little bump and shakes just cruising down the freeway. Tires have been rebalanced twice and I tried a different set of wheels on my own. I am seriously considering taking a huge loss and trading this thing in as there is no way I am going to deal with this truck on a daily basis. I have searched and found many other people with the same problem and no real solution. It feels more like a suspension issue than a tire issue. Any suggestions?
Welcome to Titantalk.
Where did you search that you found many people with the same problem?
A competent mechanic can help you determine if there's excessive play in the front suspension. It can happen and can be fixed and should be under warranty if it has only 1000 miles. If it is as bad as you say, a drive with a tech could clearly tell them the problem.
You've changed out tires so that issue is negated with tires being out of round.
Be advised that coming on to the Forum as your first post and complaining about the truck will attract a lot of attention to the tune of being called a troll. Thought I would let you know that people are skeptical of helping someone who posts how much they dislike the truck and really doesn't seem to want help...
HippieWhore™
Kronos1965 is offline   Reply With Quote
