Old 01-06-2009, 02:47 PM   #9 (permalink)
import2nr
import2nr's Avatar
Send a message via AIM to import2nr Send a message via Yahoo to import2nr
Re: 08 Titan drives like paint shaker
have you had the tires ride matched. My second set of good years were horrible ... and i went through a set of 4 ( out of round but still balanced out to zero.. idk how but it did )before getting them balanced / ride matched right ... tires can balance out to zero but unless they are ride matched then you still might have issues( no im not a tire guy just telling my experince) ....they were within the load range but very high border line ... if i remember some were at 32lbs plus .. i forget the exact terms they used ... and the OKAY
tires were at like 18 ... but i had to keep going back and back and back to discount tire then someone finally mentioned getting them ride matched and that fixed the problem ...
i think they are ride matched from the factory but you never know ....
just my two cents
***Dynod before headers @ 272hp 334tq***
*2004 Galaxy Black SE CC
*Rockford Fosgate Punch 200 a4
*One 10" Kicker Comp down firing
*Omega MAX-E Remote Start/Alarm with pager remote
*ECO Systems Fuel Enhancer
*Volant PowerCore CAI / Ram Air Scoop
*AIRE TBS
*2 Degree Timing advance
*Doug Thorley LT Tri Y's
*Used to have AT3030XL muffler / 3" exhaust piping from MF "Y" back ... Now back to stock exhaust
*Magnaflo HF CATS #94165
*Hoppy EasyLift Tailgate Lift Torsion Bar
*Black Alteza style tail lights
*Lund S.S. bug deflector
*NCD 2" Leveling Kit W/ Bump Stops
*Ikon shocks with 1" block in the rear and Bilsein 5100's in the front ( adjusted to middle notch)
*Nitto Terra Grapplers LT285/65R18E1
*Chrome Range Rover Fender Vents
import2nr is offline   Reply With Quote
