Thread: Abls
Old 07-01-2004, 06:57 PM   #11 (permalink)
bwalkertitan
bwalkertitan's Avatar
If the ABLS system is activated, the
slip indicator light will blink and you may hear a
clunk noise and/or feel a pulsation in the brake
pedal. This is normal.
Ok IMADOGMAN - I just went and checked it with my own truck, so you can believe me. I turned off the VDC and while taking a corner mashed the gas pedal to see if the SLIP light would illuminate (from the above statement, that would identify the ABLS being active). It did illuminate with the VDC off, so it was active (It also made a big burn out - with increasing power until I let off the gas).
If I mash it with the VDC on, the SLIP light comes on, but the VDC limits power and the slide burnout stops.
2004 Smokin Nissan Titan SE CC 4x4
-Big Tow
-Offroad
-Banks
-K&N Drop-In
http://www.calidrifting.com
Last edited by bwalkertitan; 07-01-2004 at 07:18 PM. Reason: misplaced end parentheses
bwalkertitan is offline   Reply With Quote
