Oh and here is what my owner manual says verbatim from page 5-29.
"If the vehicle is operated with the vehicle dynamic control system off using the VDC OFF switch, all VDC and TCS (traction control system) functions will be turned off. The ABLS and ABS will still operate with the VDC system OFF. If the ABLS system is activated the slip indicator light will blink and you may..."
SO in actuality, believe me (because I just tested it per above post) and believe the manual which clearly states that the ABLS is functional when the VDC is off.
