I had looked at those rims but, without a lift kit, because of the offset and backspace measurements they would have caused the tires to rub. You can do a search on here to learn more. There is a bunch of information on the topic and that's what helped me through the process. Basically those measurements determine how the wheel, and therefore the tire sit in the wheel well. Having the correct bolt pattern doesn't mean the wheel will work. When I was looking at the DC wheels I was told that about 4 to 6 inches of lift would be necessary depending on tire size. Here's a couple links to get you started.
whats the stock 18" rim offset/backspace etc?
CAN I REALLY FIR 35's WITH A 6 INCH LIFT ??
