Old 01-08-2009, 10:50 AM   #49 (permalink)
TJ Kretschmar
TJ Kretschmar's Avatar
Re: Front Axle Failer Thread
Originally Posted by n o o d l z View Post
How hard is it to replace on your own? What tools are needed out of the ordinary?
I have a bracket lift, so it might be easier than a none lifted truck...not sure. All you have to do is unbolt the upper cv joints from the carrier (12 bolts, easier to do with the front tires off the ground), then the 3 bolts holding the carrier in, and finally the drive shaft (might want to check the u-joints while you are at it, they should not have any play in them). Normal hand tools and a couple of jacks will get the job done. I used an impact to remove the CV bolts (I don't recommend an impact to put them back it, I had one of them snap off on me).
She's BIG,
6" Pro Comp Stage 1, Radflo 2.5 Coils, Modified Reservoir Brackets, 2.5" Deaver Mini Pack, Bilstien Rear Shocks, 3" Pro Comp Aluminum Block, Buckstop Bumper, Modified Factory Skid Plate, 150 Watt KC Hilites, AmSoil Air Filter, Retrax Tonneau Cover, Northern Tool Toolbox, 315X70R17 Mickey Thompson MTZ, 17X9 **** Cepek Black DC-1, Bushwacker Flares
TJ Kretschmar is offline   Reply With Quote
