Old 07-05-2004, 08:13 PM   #7 (permalink)
canman
canman's Avatar
Send a message via MSN to canman
Originally Posted by pciley
Judging by that bundle of split loom in your picture, if that is ALL of the wiring that was supplied... If there is no relay next to the power lock in the cover, then I would have to say no relay was supplied. The wires are already in split loom which is very nice. You can run this up into your cab, hopefully through an existing hole of which there are several. Then under your dash and to the BCM wiring to get at those power lock signals for your relay(s) that you might need to buy.
pciley,
Thinking about this more, I don't think I will need to get a relay. I am no electronic pro, but there is a solenoid that is inside the cover in the attached pic. I agree with you that running it to the passenger power door locks is the way to go, but I am still looking on how to run the wires.
Does anyone have any good ideas on how to run the wires from the bed (w/spray in bed liner) and back into the cab. I took a quick look under the truck (not on jacks) and it does look like there are some holes to go into, but I am not sure exactly where to go once I get in.
canman is offline   Reply With Quote
