Old 07-08-2004, 06:56 PM   #3 (permalink)
Titangasm
Titangasm's Avatar
I disagree. Herculiner and Duplicolor are the lowest priced, lowest quality stuff you can buy. Have a spray-in professionally put in.
None of spray-ins are perfect, but you will have the best luck with LINE-X. I have researched bedliners and I have very detailed technical information about many of them that are on the market. Most of the liners are 100% polyurethane, some are 100% polyurea, and LINE-X is a mix of polyurea and polyurethane. The mix makes LINE-X have some unique qualities such as higher temperature tolerance, higher chemical resistance, higher tear strength. And, LINE-X is the only spray-in bedliner with a NATIONWIDE lifetime warranty. Let me know if you have any questions about any of the liners.
The only draw back is that it is intended to be a permanent liner. Don't worry if you get Herculiner or Duplicolor, it will come out by itself anyway in a year or two.
Titangasm is offline   Reply With Quote
