Old 07-09-2004, 07:07 AM   #14 (permalink)
bvstone1
You keep throwing Duplicolor in there as well. All of the folks I've talked to on the forums that use Herculiner couldn't be happier with it. Duplicolor may be another story, but I've never personally used it so I can't comment.
And you apply it with a roller, using a brush in corners and other areas.
Prep is a b*tch for any liner, and if it's not done right, it will chip. Just look at the Titan factory liner. Perfect example. But if done right, Herculiner will not chip under normal circumstances. And that is from Personal experience.
bvstone1 is offline   Reply With Quote
