I can only see one big radiator with a small 4x8" cooling coil mounted above the elec fan. There are two lines from the tranny up to the radiator also. I guess my real question is do I need to upgrade to an additional external cooler. Nissan doesn't make this very clear. This is from the Nissan website
__________________________________________________ _______________
Big Tow Package (SE, LE)
• Increased tow capacity
• Extendable tow mirrors
• Receiver hitch
• Lower final gear ratio (3.36:1)**; similar to a four-speed automatic 4.10:1
• Additional seven-pin wiring harness plug
• Trailer brake controller pre-wiring on IP.
• Transmission temperature gauge
• Heavy-duty battery (710 CCA)
• Vehicle Dynamic Control (VDC)*
They only note a trans temp gauge, not a higher capacity cooler.
