Originally Posted by FLfinfan
What is the difference between the rear differential and the final drive? I have already changed the fluid in both diffs. What/where is the final drive?
nothing really but it has two different meanings. Final drive is a reference to ratios more than it is to a component. The rear diff will have a set ratio (ring and pinion), whereas the final drive ratio will be a different number when the transmission ratios are taken into account. But when it comes down to it, no difference...
