Old 07-22-2004, 05:29 PM   #7 (permalink)
Speed-Freak
Speed-Freak's Avatar
Stillin/Brake Pros is already working to have Goodrich tool up to make Titan/Armada stainless brake line sets. Also, Stoptech has stainless lines on thier big brake package for the front.
May want to call these companies and see how far out they are from having stuff on hand.
Also, the brake system problems are not because of the lines. A Corvette has "rubber" hoses and stops just fine. Adding the stailess lines to our current brake setups would probablt make the problems worse. I had a Passat the I did stainless lines and Mintex red box pads on with DOT 5 fluid. Warped my stock rotors in just a couple months. Just changing the lines on our trucks and running DOT 4 or 5 fluid will probably make the system hetup/fade faster because of the increased clamping forces and reduced clampping force drop as the brakes are applied.
Persoanlly it still feels like heat fade. Brakes are really good and grabby till you get a bunch of slow stops in them or one real good 60-0 hard stop. Then they are mush till the thing sits. Just the same as what my Passat was.
SF
LE 4x2 with Nav
Smoke / Sand and Steel
Speed-Freak is offline   Reply With Quote
