33's are what come stock, so that's obvious. Wheel width and tire width are what make the difference. I think you'd have a hard time fitting a 35x12.50 tire on a Titan without 5" of lift. Same goes for the 33x12.50, I think it will rub at stock height, hence the 2.5" coil spacers. There was even one memember who has the CST lift and his 35x12.50R17's rubbed on a 10" wheel and had to install the 1" coil spacer.
-Counsel Yourself
