I have it and the plate, It was a little tricky to do. Had to trim out part of the front skid plate where the bar drops down. Kind of a pain since I had to put it on and then take it down a handfull of times to get it right, I didn't want to just cut the front off of the skid plate. I had to try and wiggle it and push it a bit to try and line the bolts in the front back up before I could tighten them. The two screews that hold it up in the back were about a half inch off. I have some self taping ones I was thinking of using to hold it back up but haven't dont it yet. The 4 up front hold it up with out them. The skid plate on the bull bar, I had to unscrew the bottom to alow it to fit over the front skid plate on the truck. With that it sits about an inch away from the original hole so screws don't fit. I keep running things through my mind and looking at it to see if there is a way to put it back up but it's held on by the top and pushed up againts the trucks skid plate. Here are some pics of mine. Give you an idea of how the cut was.
White LE CC 4X4, OffRoad, Big Tow,Nav, DVD, back up sonar, sun roof, bug and window deflectors, Westin Bull Bar, K&N aircharger, A.R.E. bed cover, Centerline Stingray III's 17X8s, Utility Bed Package, W/ sliding bed extender and divider, Side air bags, all leather, Captain chairs. http://www.nitrousenterprises.com/ 3 inch Lift Kit. BFG 315/70-17 A/T
