Old 07-30-2004, 04:15 PM   #12 (permalink)
TuffTitan
Just picked my Titan up from the dealership and they turned the rotors. I asked about new brake pads since it was part of the TSB and they said, "if they do it again, then they will replace those". My biggest concern is with regards to these brakes is when you are towing a heavy load. Previously, I got used to the slack in the pedal, but I never got into a panic stop situation. If I strap my 7800lb Bobcat on the a55 end and the stoping power isn't there as a result of faulty brakes, Someone is going to get a 13000lb projectile in their rear end. I hope Nissan identifies a solution because inevitably someone is going to encounter this situation. Its one thing to have enough stopping power for the weight of the truck alone, but when you start adding towing weight, it is a whole different set of tolerences.
TuffTitan is offline   Reply With Quote
