speedbleeder city
I ordered and received speedbleeders. they are a special one-way bleeding screw for brakes. you need 4 of them and they allow one person to bleed the brakes to perfection. also makes it easy to pump out old brake fluid and install new at the same time. they have a one-way valve that lets fluid out but keeps air from getting in. If you like to keep your brake fluid fresh and working, the speedbleeders make it much easier job and your wife doesn't have to come out and pump the brakes - domestic tranquility. Anyway, speedbleeder didn't know the size but guessed 10mm with a thread every milimeter. It was right on. part number 1010. They are a little longer but still go under the original bleeder cap which is what I recommend. the speedbleeder supplied caps are hard to get off once on. the original bleeder screws need a 10mm wrench but the speedbleeder screws use a 3/8's so make sure you change wrenches and not round off the bleeder. I installed mine today in preparation for installing the SS brake lines from crown which I also received this week. pumped up a big fat pedal with the bleeding and I'm done modding for the day. juma
