Re: How to install remote starter
Thanks for your help. Did you just tap in to the purple wire. You dont have to run it through the relay. And I take it the blue wire on your remote start is the activation imput. Mine is Yellow brown so I will use that. So I and going to take wire and hook it to 30, and 85, Run these wire to ground, Than take 86 and tap off the purple wire for this. They Hook my yellow brown to my 87 terminal. Now I should have a - pulse wire. ? Thank you. Let me know if I am hearing you wrong. Again thanks for the great detail.
