Old 03-18-2009, 11:37 PM   #16 (permalink)
src4usarmy
src4usarmy's Avatar
Re: How to install remote starter
Originally Posted by Mighty Whitey Titan View Post
Thanks for your help. Did you just tap in to the purple wire. You dont have to run it through the relay. And I take it the blue wire on your remote start is the activation imput. Mine is Yellow brown so I will use that. So I and going to take wire and hook it to 30, and 85, Run these wire to ground, Than take 86 and tap off the purple wire for this. They Hook my yellow brown to my 87 terminal. Now I should have a - pulse wire. ? Thank you. Let me know if I am hearing you wrong. Again thanks for the great detail.
I don't know how your remote starter needs to be hooked up because it may be different from mine but the way mine is setup for the starter to start the truck by using the factory fob and hitting the lock button my starter needed to receive a signal from the lock wire and it had to be neg. but that purple wire sends out a pos. pulse. The only thing the relay is for is to change that pos. pulse to a neg. pulse that is going to the remote starter. The wire from my remote starter that received the signal was a blue wire but your may be different, just follow the directions and you should be good.
src4usarmy is offline   Reply With Quote
