Old 04-01-2009, 03:45 PM   #470 (permalink)
SarkaZm
SarkaZm's Avatar
Send a message via ICQ to SarkaZm
Re: Brake Recall Info
Originally Posted by BigHeadDennis View Post
I think these brake issues are hugely correlated to how the owner USES the brakes; i.e., some guys are much tougher on brakes than others. ADK, you'd be looking at the current spec brake pads (and rotors), so any initial issues with the brakes should be addressed by now, wouldn't it?
FWIW, my early-'06 Armada has 68k miles, mostly suburban family hauling but I tow a heavy (6000lb) trailer about 5-6 times a year. The dealer installed new pads and rotors on the FRONT at 61k miles. The rears? The shop said that the rear brakes were only half-worn, and I could expect it to last until 90k-100k miles, most likely. Nice surprise. And never had any shuddering issues.
vty,
--Dennis
I do not buy this! We are talking brakes on a truck. These parts, if any, should be overbuilt to withstand tough use. I have had 3-4 brake jobs (i keep forgetting) and have yet to tow anything and rarely haul anything substantial. My truck is babied for the most part. I believe this issue relates more to a design flaw on Nissan's part of the 04 and 05 builds. Dennis I see you have an early 06 so chances are you have the newer brakes already.
ADK Stomp, I would just be sure you are getting the updated rotors or, even better, a nice aftermarket set and you should be fine. Since I installed a set of DBA rotors myself I have not had any issues (with the brakes anyway).
Good Luck
More Pic's Here
SarkaZm is offline   Reply With Quote
