Old 08-07-2004, 10:05 PM   #3 (permalink)
ChrisCakes
ChrisCakes's Avatar
Check the leaf springs...
Have had the same annoying squeak for some time... The rear shackle (mounting bracket) on the left leaf spring was rubbing against the springs... Sprayed it with WD-40 and the squeak went away... I live on a dirt road, so it wasn't long before it came back... Will probably need to "persuade" it a little with the right sized hammer... Actually, there was enough space on the other side of the shackle, so adjusting it should permanently solve the problem...
ChrisCakes is offline   Reply With Quote
