Old 08-08-2004, 03:50 PM   #1 (permalink)
Titan4x4Aggie
Titan4x4Aggie's Avatar
Saturday Adventures
Part I
The day started with a trip to Advantage Nissan for my 3750 mile checkup, which included oil change and a check of front and rear diff fluid levels. I also said my truck was included in the radio TSB, which I presented, and told them I was having the fade issues.
So, they worked on my truck, and the mechanic came out and told me they didn't have a fix for the radio because Rockford Fosgate doesn't know what's wrong and doesnt' have a fix for it. And the conversation progressed as follows:
Me: "Actually, Rockford Fosgate doesn't make the radio, or any part of the sound system. The radio is a Panasonic."
Joe: "That doesn't matter, either way, RF or Clarion, they haven't figured out the problem"
Me: "That's odd, because Nissan has issued a service bulliten for the radio."
Joe: "Well, there wasn't anything wrong with the radio."
Me: "Did you drive it? It does it every time I go to work, in the same area of the road. The treble fades in and out, just like the TSB describes."
Joe: "Oh, well I saw some sort of power cable running from your battery. Did you install a sound system?"
Me: "Yes, I installed an amp and sub."
Joe: "Did you use crimp-butt connectors? Because Nissan only approves of soldering. That could void your warrenty."
Me: "Yes, I used butt connectors, and that's not my radio problem. I've installed many radios, and I know how to do it."
Joe: "Oh"
So the mechanic talked to the parts guy, and the parts guy told me he would order me a new radio and have it here in a week. They also asked if they could have my copy of the TSB, and I said yes and gave it to them.
My "new" radio arrives in a week. It better not have these problems either. ie, they better not pull some old one off the shelf.
Part II
The gas light came on in Clear Lake, and seeing as how the light is overprotective by about 5 gallons, I figured I would fill up in Houston after driving 30 miles to IKEA. Well, I arrived, and traffic was bad, so I figured I would fill up on the way home back to clear lake...but didn't quite make it. 10 miles outside of town, by the Beltway 8, I ran out of gas.
Took 26.5 gallons to fill up, after adding 1 gallon to get me to the nearest gas station. 340 miles on 27.5 gallons...
My new gas saver!!!!!!
