Nice, I will give you some helpfull info. If you would like to Hard wire your GPS the connector is only acouple of dollars at Radio Crap and wire is pretty cheap. If you dont like to splice into wire you can run it to the fuse box and there is a Blue wire with White Strip in the bottom left corner. It is up front and not in back of the fuse box. Unplug it and remove it from the Harness. You can just strip alittle of the new wire away and there is a solderless connection. Loop it threw and Put is back in. Ground out your Negitive and BAM your done. Took me Only like 15 min. to do my Radar Detector. I hate having the phone cord going from my cig. lighter to the Radar Detector, gets in the way of putting cd's in. Just some FYI for you but otherwise it looks great. Do you know if the Carbon Fiber comes with the Double din Cut out? Josh
