Re: adding power seats?
This is what i figured out on the drivers side seat:
green wire appears to be the remote/accessory wire (hooked up to ignition or in my case my amplifiers remote wire)
thick white wire is constant (connected to my 12V power source i.e. battery)
black wire is ground
green wire with white stripe is ground (i could have connected these to the seat bolts but i just went ahead and connected them and everthing else to my amplifier power/ground/remote sources
This is what you need to get the motors going driver side. the passenger side is just a power and ground (black is the ground)
(if you are pulling the seats out of a wreck or parts truck cut the factory wiring harnesses well below the connectors so you can still disconnect the seats if need be.. it makes a lot of difference.
---- i will let you know when i figure out the memory seats and heaters.
