Old 08-09-2004, 09:26 PM   #8 (permalink)
Mike H.
Mike H.'s Avatar
Originally Posted by ChrisCakes
Have had the same annoying squeak for some time... The rear shackle (mounting bracket) on the left leaf spring was rubbing against the springs... Sprayed it with WD-40 and the squeak went away... I live on a dirt road, so it wasn't long before it came back... Will probably need to "persuade" it a little with the right sized hammer... Actually, there was enough space on the other side of the shackle, so adjusting it should permanently solve the problem...
I had the same problem on both sides. I used Tri-Flow. When it comes back, I'll try the BFH.
Mod links (clickable):
