Old 08-10-2004, 12:24 PM   #1 (permalink)
sasilverbullet
sasilverbullet's Avatar
Trailer Towing Recommendations...
Now that I've had my Titan and trailer for a month, thought I'd share my experiences -
Truck is a LE Crew 4 X 2 with big tow package.
Trailer is a 2004 Cheyenne model 29Z (w/slide out). They're built by Forest River. It weighs 7,900 dry, with a 725 lb tongue weight.
I'm using Reese's new anti-sway/equalizer bar set up. It really helps pull it better. When I first purchased the trailer, I was using a standard old equalizer hitch. Had a LOT of sway. But this is all because of the trailer, not the truck.
When we pull the trailer, we have about 750 lbs of human flesh in the truck, and I'd estimate the trailer to be at around 8,700 lbs.
The ride is excellent. Keep in mind I've pulled other heavy trailers with various other tow vehicles. None of them even comes close to the Titan.
We just got back from a 450 mile trip, pulled like a champ. I kept it between 60-65 mph the whole way. In 104 degree heat, lots of humidity, the temp gauges never budged.
One suggestion - I changed my engine oil to Mobil 1 15W-50 and the rear dif fluid to Mobil 1 synthetic also. I HIGHLY recommend you do this also. This oil holds up MUCH better than the dino oils do under severe stress.
sasilverbullet is offline   Reply With Quote
