Old 04-18-2009, 10:35 AM   #5 (permalink)
MXtitan24
MXtitan24's Avatar
Re: Where to put amps in Crew Cab
Originally Posted by AZTitan2004 View Post
If you have it under the front seats wont the amps over heat from the ac/heater vents rigjt by the amp. The reason why i dont have it behind the rear seat ia because its to hard to get to if you need to adjuat anything. Do you have a pic of your setup
it's harder to adjust the amp under my seat then on the back wall because you have to pull it out because there is no room to work under there. IMO backwall is the best
MXtitan24 is offline   Reply With Quote
