Originally Posted by JetTech
I've noticed you seem to be quite a fan of the 15W-50 M1. To support your recommendations do you have any plans of doing an oil analysis of this oil? The reason I ask is because I would guess that your experiencing high bearing wear with such a thick oil and I would very much like to be proven wrong by an oil analysis. It only costs 20 bucks through blackstone so how about it??
i run valvoline HP 20W50 in my rx-7. 20W50 is recommended by my mechanic and rx-7 owners everywhere, since the engine runs hotter.
as the oil heats up (and stays hot here in texas), it will flow better. also, i imagine the heat capacity of oil is dependent on temperature, so if the oil is hotter, it might carry the heat away just as well as a thinner oil and yet protect better.
lots of variables here...
